Hi Friends,
While monitoring the Rapid mart Job I found one of the rapid mart job Purchase rapid mart failed.
When I checked the error logs I found the following error
[b][i]Row delimiter was seen for row number <439155>
in Rapid mart while processing column number <36> in file <Pth-]
the row delimiter should be seen after <49> columns .
Please check the file for bad data or redefine input schema for the file
by editing the file format in ui[/i][/b]
Please assist in resolving these error
Please find the attached snip
Thanks in advance
Fasi
Md_Fasi (BOB member since 2011-11-19)
