roll up of values in a dimension
I am facing a problem with the roll up of values in a dimension.
I have a dimension with 3 values at universe level.
Letters
A
B
C
Now I want to add one more value to this dimension, which is D, but it should be sum of A+B. So list of values for new dimension should be:
Letters
A
B
C
D
But when I am using case statement as follows:
case when Letters In (‘A’,’B’) then ‘D’ else Letters end
Then the Values for A & B getting disappeared.
I am getting result set like this:
Letters
C
D
How can I get all the 4 letters to be displayed (i.e. results in 2nd case above) ?
Any help is appreciated.
Vikram
vikramvasisht (BOB member since 2008-02-18)
What database are you using? Have you tried running the query generated in a different query tool? What happens when you run below query:
Select Letters, Case Statement, sum (kpi)
from Table
group by Letters, case Statement
BOB_DW (BOB member since 2004-08-26)
Thanks for the reply.
I am using SQL server 2005.
I want to do it at Universe level within the dimension. So would like to avoid any “group by” conditions.
You need a UNION query…
SELECT Table1.Col1
FROM Table1
WHERE Table1.Col1 in ('A','B','C')
UNION
SELECT (Table4.A + Table4.B) AS D
FROM
     (SELECT Table2.Col1
       FROM Table2
       WHERE Table2.Col1='A'
       UNION
       SELECT Table3.Col1
       FROM Table3
       WHERE Table3.Col1='B')Table4
You should get:
A
B
C
D
