Right to send a report
Hi !
I’ld like to know wich right I should affect to some user in order to allow him to send a report to one of his coworker.
Thanks for your answers.
Guilhem
GuilhemDevaux (BOB member since 2010-04-20)
And when I connect with a similar profile (user-profile) and I click on “Send to”, the list of users whom you can send it is empty and I can’t search any other users.
You need to setup the security on groups also… Groups are objects like others thus you need to create a security matrix to be able to see the suitable groups when sending reports to others…
Regarding your first question this post should help you …
