Right to Export Universe
Hai
I had a user with Administrative previllages.
But while opening Designer and exporting the Universe to BOXIR2 repository it is
saying
"You Do not Have Right to add objects to folder ‘/’ "
can any one say what is wrong
Byee
Anjaneyulu :india: (BOB member since 2008-03-20)
Double check rights your user has on the universe folder …
Hi Anjaneyulu…
Check whether the user has "Add objects to the folder’ right under CMC > Universes rights.
Raj_admin :india: (BOB member since 2008-12-04)
Hai
Can you Explain about t “Double rights your user has on the universe folder”
i checked
Add objects to the folder’ right under CMC > Universes rights. it is enabled(Granted)
Sory double check. I mean check the right add objects to the folder for that group on the universe folder where you want to export your universe
hi
did you figure this out, i am using the administrator account and i have given the rights to add objects to the folder ( top level security for the universe) but still i could not export the universe.
Environment : BO XI 3.1
bdharma (BOB member since 2008-07-07)
Hi try with this and let me know.
CMC Home> Universes> Select required universe folder
Give the security right to the user
Content >Folder:Add objects to the folder
Arjun (BOB member since 2008-07-28)
I have given Full control for all the folders (top level security) for both Administrator Group and Every one Group ( just to make it work initially;) still i could not able to export the universe. I checked for “Add folders…” rights too ,it says its granted.
(Note: Even i have tried with “Advanced” and given all the options but i could not., then i have given Full control to the Temporary Storage but in vain…)
So you made sure you have complete access to the folders, can you check inthe applications->Designer and see (i would think admin will have full control) but just to make sure “Check User rights”.
Abishek :us: (BOB member since 2004-12-09)
Abishek,
I apologize for the belated reply; I checked all the rights (even opened a case with BO SAP support ) but everything was fine in the security.
The issue was fixed once i uninstalled and re-installed the client tools
