RFI/RFC: Set Analyser replacement ?
Hello,
to those BO users who have used, or are using, the BO Set Analyser product:
I understood that Set Analyser has been declared End Of Life, and no new product development or upgrades will be forthcoming.
Does anybody have any good pointers towards replacement products?
(SAP or otherwise, however I believe SAP veers towards solutions built on top of Hana).
Best regards,
Ruben
rsa :belgium: (BOB member since 2008-07-11)
Hi Ruben
A sad day for a lot of people when BO end-of-lifed SA :frowning:
As far as I know there are two products out there that do this, but neither are SAP! They are Qlik and SAS.
Happy going
SarahG :australia: (BOB member since 2005-08-22)
Hi Benty
Qlik uses the term Set Analysis but doesn’t Implement it in the same way BO used to. www.qlik.com
SAS - the statistical analysis tool - www.sas.com is probably the best tool in this arena, but might be too overboard for the rest of your BI application requirements?
I would suggest you look into each product individually and draw up your own list of pros and cons based on your requirements.
