RFC problem empty file
environment:
data services 14.0.6.1100 on window 2008 R2
Hello,
i want to get the data with the RFC connector from an R3 system. i can import the tables, i see the structure of the tables and i can see column values.
whre i launch the job (target MS SQL), i receive no data, but the job is successfull. in the log i see “empty file received”.
i controlled, that the “Unicode-Flag” in the definition of my Connection is enabled.
Any idea?
Thanks a lot
Roland Jentsch (BOB member since 2006-02-07)
