RFC call receive error Function Z_AW_ABAP_INSTALL_AND_RUN
I am trying to Execute ABAP data flow getting the above error, when i spoke to basis team they said The client A is not open for Repository changes. You have to make changes in client B and then SCC1 to A.
How should i approach this ?
Urgent help appreciated
surya.sap (BOB member since 2012-07-30)
I think you will need to set dataservices to execute only (rather than generate an execute). The code will need transported from B to A by your Basic guys.
This assumes you are able to run your job against B first though…
Leigh Kennedy :australia: (BOB member since 2012-01-17)
This thread may also be useful to you:-
Nemesis :australia: (BOB member since 2004-06-09)
