Hello together,
is there any possibility to handover a null value to an XML (file/message) output/web service call if the field to be transported is optional (minOccurs=0)?
Example: Assume the following XSD
<complexType name="Type_Bodsdemo8_Params">
<sequence>
<element name="string1" type="string"/>
<element name="string2" type="string" minOccurs="0"/>
</sequence>
</complexType>
<!-- input element for use case create ticket -->
<element name="Bodsdemo8_Params" type="bds:Type_Bodsdemo8_Params"/>
Now map string1:=null and string2:=null. The outcome XML will be the following
<ns1:Bodsdemo8_Params>
<ns1:string1></ns1:string1>
</ns1:Bodsdemo8_Params>
, which is in some of our use cases not the desired output. Expected is:
<ns1:string2></ns1:string2>
Fortunately, string2 can be mapped to strings2:=, which will result the desired answer.
But if one wants to send an optional integer containing a null value, this empty-string trick will not work. Is there any possibility to send a null value for optional integer without changing the WSDL? (Unchecking Optional in the query designer wont work.)
Nevertheless, I would expect BO DS to clearly distinguish between a nilled and a non-occuring field (nillable=true vs. minOccurs=0), which is obviously not the case. Not mapping a field and mapping a field to null will have the same outcome for optional fields in BODS, which is a semantical difference.
Is it known that this is a BO DS implementation issue or is there another way to handle the described case?
Best thanks,
Sebastian
Versions:
Designer 14.0.3.353
JobServer 14.0.3.353
JobEngine 14.0.3.678
Repository 14.0.0.0000
pose (BOB member since 2013-02-20)
