retrieving a specific instance from an hyperlink
Hi all,
I want to retrieve each instance for a same document from a hyperlink.
My document contain a prompt for each region (6). I’ve done 6 schedule of this docment (using each region in the prompt value parameter)
I want to create 6 links and define in each link the according instance.
I’ve used the parameter option but it doesn’t work
http://my_Server/BOE/OpenDocument/opendoc/openDocument.jsp?sIDType=CUID&iDocID=my_ID&sInstance=Param
:hb:
I do not want to duplicate the document, but if there is no solution I will do so and use sInstance=Last.
Can someone give me an example please?
Thanks a lot
kakounj (BOB member since 2004-05-14)
