BusinessObjects Board
Results from formulas not displayed - HELP
I have a formula in Excel in Dashboard Designer I used to retrieve data from a Webi table:
IF(ISNA(VLOOKUP($B16,T$32:T$82,1,FALSE)),"",VLOOKUP($B16,T$32:T$82,1,FALSE))
This gives me the results I need with the exception that it pulls it in with spaces between some values (i.e.)
A
B
C
D
E
So I have a secondary formula in Excel which removes the spaces and the results look fine:
IF(ISNA(INDEX(D$16:D$21,MATCH(0,INDEX(COUNTIF(D$22:D22,D$16:D$21),0,0),0))),"",INDEX(D$16:D$21,MATCH(0,INDEX(COUNTIF(D$22:D22,D$16:D$21),0,0),0)))
A
B
C
D
E
until I go into preview. Then I get nothing. Can someone help to determine the issue here? All functions are supported.
fknaut :us: (BOB member since 2005-08-04)
Basic troubleshooting tips:
Have you checked that the WebI block is writing data to the original area (T32:T82)?
Have you checked that your first set of formulas is writing data to the secondary area (D16:D21)?
Have you tried breaking down your formulas to see if each individual condition is returning the expected results?
