Restrict drill down on measures
Hi All ,
I am using cross tab to show data and appying drill down functionality on vertical columns(Having Dimension) but it automatically showing drill down functionality on measures also. I want that i can able to drill down and up on basis of dimensions only.
viv181986 :india: (BOB member since 2010-04-30)
If you donÂ’t want the drill down options for the particular object in the report, create as the local variable in the report and placed on that place.
Arun
arung :india: (BOB member since 2007-07-18)
Thanx
arung
