Response Filterreport
Hello, I would like to know if in a report it is possible to store the result of an input control or a filter in another block as a variable?
Create a blank field
Formula is =ReportFilter([What you are filtering by])
Or
you can use the predefined field to give you all the filters in the report
Depends on the type of input control you are using and how you are using it. If it’s a static list of values entered into the input control or a value box that users type into, you can create a variable and set it as the source of the input control and use it in filters or other variables.
