I might sound stupid but i can’t figure out how to resize a column set to 0.001 inches width, at the end of a table. Does anyone knows how can i do this? I can’t get to that colomn to right click on it and access format options
Try dragging it - if you start from the right, as soon as the icon changes to the resize column icon - looks a bit like this || - then hold your mouse button down and drag it to the right to expand the column.
I tried this but it will resize is not working so i deleted the variable i had in that column and BO deleted the column from my block and after that i recreated the variable and us it. is not the most elegant solution but it solved my problem. Thanks for your advice!
