Resetting page numbers
I am using BO 6.5.4.
I have a report that shows transaction details for customers. The users have requested that the page numbers be reset each time the customer changes.
The report has a section on the customer number and is formatted to start each customer on a new page. Some customer details go over more than one page.
Any help that anyone can give would be greatly appreciated.
Fherry :barbados: (BOB member since 2007-03-21)
The only solution that i can remember implementing is
PageInSection()
Format your section so that it shows only one value per page and have this function called within that break. This would work.
boe_bods :india: (BOB member since 2008-03-14)
This does not seem to work, or maybe I have misunderstood you.
If I use =PageInSection(), I get an error. The function needs a parameter. If I use =PageInSection(SectionNumber()), the result is ‘1’ on the first page; however, every other page shows ‘0’.
Try doing PageInSection(1). Would that work for you?
This is not perfect. I will have to change the format of the report somewhat; however, it will work.
Thank you for your assistance.
