Reschedule/ Replace existing schedule
Hello,
I’m a BO user (BI 4.1 Support Pack 3 Patch 5) and I have to schedule a BO report from an existing schedule.
When I click
, The values of the prompts selected before are not displayed.
Someone knows how to keep the selected values from a prompt in the planning?
Thanks for help
Carmen
carmencita (BOB member since 2017-05-12)
You can set the “Prompt Properties” within the query of the report to “Keep last values selected”. That might work.
peacha :uk: (BOB member since 2008-07-31)
thank you very much, it works
Now, I have another problem :
I have to keep all instances of a BO reporting schedule, for sysdate -10 (the last 10 days)
I don’t find the documentation
Thanks a lot
In the Central Management Console: Find your report, right click and select “properties”. Then select “limits” and you can set the limit on the number of instances to be retained. Hope that helps
Hello,
It is worth noting you would normally set this at the folder level.
