I want to retrigger all the failed schedules using a java jar file on cms. just for testing i wrote this below program which i suppose would retrigger a certain schedule (which is success already) >Please help me find where did i go wrong since it shows success when i run this program on cms but the schedule doesn’t get triggered
public class Schedule_CRNA implements IProgramBase {
public void run(IEnterpriseSession enterprisesession,IInfoStore infostore,String str[]) throws SDKException {
//System.out.println("Connected to " + enterprisesession.getCMSName() + "CMS");
//System.out.println("Using the credentials of " + enterprisesession.getUserInfo().getUserName() );
IInfoObjects oInfoObjects = infostore.query("SELECT * from CI_INFOOBJECTS WHERE si_instance=1 and si_schedule_status=1 and SI_ID=9411899");
for(int x =0;x < oInfoObjects.size();x++)
IInfoObject oI = (IInfoObject)oInfoObjects.get(x);
IInfoObjects oScheds = infostore.query("select * from ci_infoobjects,ci_appobjects where si_id = " + oI.getID());
IInfoObject oSched = (IInfoObject) oScheds.get(0);
Integer iOwner = (Integer) oI.properties().getProperty("SI_OWNERID").getValue();
oSched.getSchedulingInfo().setScheduleOnBehalfOf(iOwner);
oSched.getSchedulingInfo().setRightNow(true);
oSched.getSchedulingInfo().setType(CeScheduleType.ONCE);
infostore.schedule(oScheds);
oI.deleteNow();
riteshsinha18 (BOB member since 2020-05-24)
