RES-020107: Referencing an undeclared variable
Hi Expert,
Need help…
when I ran the job, its automatically stops, but no error message…please look at he screenshot.
Looked at the log file says: Referencing an undeclared variable <$G_JOB_ID>. Declare the variable in the context that it is being used.
But it is declared already as Global variable. It was working fine before, but all of sudden this error came up…
Could someone please help me…its more important and urgent… :hb:
aamarnath (BOB member since 2015-06-03)
Make sure someone didn’t rename the variable.
No one renamed…I have double checked everything…this happens for all the Global Variables created (more than 30 variables)
Then I would suspect some corruption in your repository. Export the job (or the whole repository) and then import it into a different repository and see what comes through.
