Repository Tables
Does anyone know if there is a published data model for repository tables? What we are trying to do is locate the table name and column names for user account data (name, e-mail address, job title, user account name).
Any advice would be appreciated.
jsull2 (BOB member since 2009-06-04)
Going directly against the repository tables is not supported and should be avoided at almost any cost.
Instead you should be able to use SDK/APIs to access most of that information. Look at www.sap.com, there should be some information about it… somewhere :wink:
Welcome to B:bob:B!
Review this utility that uses SDK to connect to CMS and extracts users’ information:
You may find it useful.
Thank you all for your help. Much appreciated.
