I’m trying ReportScript for the first time and I created a simple script to send a document to the Docagent. The script compiles successfully and everything works but when the script gets to the funtion “Result = DAOpt.Send” I get the following message : “Cannot open CustomScript file”.
Has anyone had this error before, and if you did solve it, what did you do ?
There seems to be something amis when submitting to DAS through reportscript in that you HAVE to specify a custom script file. This is a script residing on the server, not the client and I have never found a way around it.
A quick workaround is to specify a dummy script that DOES exist on the server that doesn’t do anything.
Hope it’s some help…
Phil Morris
Analyst Programmer
BITS dept.
Tarmac Heavy Building Materials UK Ltd.
PO Box 8
Ettingshall
Wolverhampton
West Mids
WV4 6JP
