Reporting Services connection
Hi all,
I try to connect to RS using the Reporting services button, but when I enter the URL of the RS server, Xcelius try to connect (no error message, only the clock icon), but never shows a reports list.
in the URL field, I enter the RS URL : http://nbang/ReportServer
In the web.config file :
Can you tell me what I did wrong ?
thanks
Denis
swissguy (BOB member since 2009-01-12)
Denis,
In order to see what is going in/out of the .swf file during preview/runtime, we use Fiddler2.
We started a whole discussion about it here in our Linkedin.com group:
http://www.linkedin.com/groupAnswers?viewQuestionAndAnswers=&gid=1847619&discussionID=3052147&goback=.anh_1847619
You might want to try it to see what is going on.
EverythingXcelsius :us: (BOB member since 2008-06-17)
