system
April 15, 2009, 5:09pm
1
I have a simple stored procedure with no parameters.When i excecute in SQL server it runs fine and gives me the result set.But when i use it as a dat source for a BO report it gives an error message.
No data to fetch.
We are in BO XI r2 sp2.
Is there anything i need to do this work.
–h
hourigan (BOB member since 2007-04-06)
system
April 15, 2009, 10:12pm
2
I have tried in ORACLE and it use REF CURSOR to return the results to BO.
I hope there is something similar in SQL Server.
BO_Chief (BOB member since 2004-06-06)
system
April 16, 2009, 12:31pm
3
Y dont you try using a free hand sql as a data source something like this…
BEGIN
EXEC sp_name
END
Try it, it works for me…
Let me know if it helps u…
anuraga (BOB member since 2009-04-15)
I am using BO XI r2 Sp4 . I also tried using a Oracle SP in free hand SQL with no parameter but i get error like “No column or data to fetch” .
When i run
BEGIN
EXEC SP_name
END
i get following erro. "Exception: DBD, ORA-01036: illegal variable name/number State: N/AI used ’
When i run EXEC SP_Name i get error like “No column or data to fetch”
I changed the odbc.sbo file also.
aroranikhil (BOB member since 2005-03-21)
