I am using BO XI R3 and Oracle database. I need to display the data returned from a stored procedure in the report. Please can you suggest me how do I implement this.
Can I directly call an oracle stored procedure from a WebI report?
or
Should I use a stored procedure universe and then create the report based on this universe? In this case how do I get data from other tables as well?
It depends if your stored procedure is returning a table, then its better to create a universe on it and then build reports off this universe
Or if the SP is just updating some tables then go for the report directly
Though I havent actually build any stored procedure universe in XI 3.1, its just a thought
If you have any clue as to how to call the stored procedure directly from the report, please can you share it. When i try to give the following syntax in the custom sql of a report, it gives an error saying “Invalid SQL”.
I am using Oracle database and I am not able to find any such parameter as given in the post in the sbo files. I used the sntax
set linesize 1000
/select * from abc/
exec testproc
But when I validate this SQL, it gives me “SQL contains 0 instead of 1 columns (WIS 10810) error”. If anyone has used the stored procedure in BO XI R3 from an Oracle database, please let me know how to implement it.
