Report Title Missing/Location Changed within Save Doc window
This is a minor change I’ve noticed since installing Fix Pack 5.6 for BO XI R2. We are on SP5.
When opening a report via the ‘Modify’ option, and when pressing ‘Save As’, the Save Document window appears. However the report title is missing (blank), and the report location has defualted to my Favourites folder.
Prior to the above Fix Pack installation, the original report title name appeared within the Save Document window, and the original report folder path was highlighted within the Location window pane.
Has anyone else experienced this?
Jamesr60 :uk: (BOB member since 2009-07-14)
Are you on Java Panel, if yes I never experienced this kind of behavior, but if you are on HTML panel, then this is not the case. It gives you the same title and same folder location.
Hi aniketp,
Thanks for the reply.
Yes - we are using Java Version 6 Update 16…
Did you try this on HTML Panel ?
Sorry for the delay in getting back to you.
It seems the problem only exists when using Firefox. Using Internet Explorer seems to fix the problem!
