Report Saved Location
Hi All
Shared full client reports 6x/ 5x -where its saved in repository ?? physical Location …
Tx
Nags :india: (BOB member since 2007-02-07)
Do you mean which tables in the repository are used to store the reports, or where is the repository database, or maybe something else altogether? I’m not sure what your question is.
Gillian :uk: (BOB member since 2005-08-18)
Hi blacknight,
In BO versions 5.x/6.x there is no FRS. All reports (those exported to the BO repository) are stored in a database table in the repository.
Please give us more details of what you are trying to achieve because your question is not very clear.
BO 5x/6x
Reports is exported to Document Domain, this report metadata stored in the repository table. i agree…
the exported reports for example .rep file where will save it ?
local copy saved in userdocs !! .
Similarly the exported reports .rep file where will save ??
BOXIR2
it will saved in FRS server … that is <.rep>
In BO 5.x/6.x, also the exported documents (.rep files) are stored in the BO repository. Specifically, they are stored in the OBJ_X_DOCUMENTS table in the binary format.
There is no FRS in these BO versions. The architecture of the older BO versions is completely different from BO XI.
Thanks Marek Chladny :smiley:
