report issue
Hello All,
I have report which use merege dimension and sub query in the firlter. When I run my report its says that there is no data in the query all the query.I ran for diffrent period and with different districts. In some time period returns data for all 4 queries,some time period returns data for 2 queries and some time period does not return data.
sub query is as below
AND
ABC.CL_WEEK_ENDING_DATE > ALL
SELECT
FROM
ABC
WHERE
trunc(ABC.CL_WEEK_ENDING_DATE+1) = @prompt(‘Enter Saturday:’,‘D’,‘ABC\Saturday’,Mono,Free,Persistent,User:0)
AND
ABC.CL_WEEK_ENDING_DATE <= ALL
SELECT
ABC.CL_WEEK_ENDING_DATE + 7
FROM
ABC
WHERE
Need advise.
Thanks SH
SH3230 (BOB member since 2010-10-25)
The first issue I see in the SQL is <= ALL.
What does <= ALL mean? Greater than or Equal to ALL? How is that possible?
:hb:
M H Mohammed :us: (BOB member since 2010-06-16)
Hello Mohammed Hussain,
What do you suggest for it? Could you please correct the query?
SH
