Report Filter and YTD calculation
I have to create a report for monthly and YTD calculation in BO which will have product,month and year report filters on top of it.
For YTD calculation if user have selected Month=“FEB” then it should give min of jan+min of Feb,but i think because of report filter applied for month =“FEB”. the formula for YTD is :-
sum(min) where ([month] inlist ("jan";"feb")
Can anyone of you help me on this.
:hb:
[Moderator Edit: Added code formatting - Andreas]
himansu rai (BOB member since 2015-10-06)
If you want a year to date figure, you may be better building a case statement at the universe level.
At the report level, if you’ve filtered for Month = Feb, you’ll only get Feb data
If you filter for Month <= Feb, you’ll get Jan and Feb, unless your months are strings, in which case you’ll just get Feb because J comes after F alphabetically.
Hi Mark,
Thanks for your reply :slight_smile:
I was trying to create 12 diffrent variables for 12 months like :
v_Jan=where month=“jan”
v_feb=where month=“jan” or month=“Feb”
V_dec=where month=“jan” or month=“Feb” or . . . . month=“Dec”
Now i am creating another variable monthly YTD which will have given formula
If month=“jan” then v_jan
elseif month=“Feb” then v_feb
elseif month=“Dec” then v_dec
so,now instead of applying filter on month, user will apply filter on month_ytd.
lets say if user have selected month_ytd= feb then he should get records for jan and feb.
but unfortunately above idea is not working. :hb:
please correct if i am missing something :frowning:
What sort of filter are you trying to create, one that goes in the filter bar?
Or an input control?
user requirement is for Filter bar :?:
thanks again :slight_smile:
Haven’t you got month numbers in your universe?
MBLM :netherlands: (BOB member since 2014-01-31)
Thanks MBLM for your reply :slight_smile:
could you please explain little more about month numbers.
I am sure that i don’t have any object like this.
please confirm is there any way to achieve this in WEBI itself.
:frowning:
The far simpler solution is to use an input control - use the slider display option and less than or equal to for your months
Hi Mark,
what could be the best possible way to implement the YTD logic in universe itself ?
Thanks in advance :smiley:
Using case expressions.
YTD on SQL Server:
SUM
( CASE WHEN sales_calendar.sales_date BETWEEN @Select(Relative Dates\Start of Current Year) AND @Select(Relative Dates\Yesterday)
   THEN sales_fact.sales_value
   END
This assumes that:
[list]You have a calendar table in your database and have created an alias of it called sales_calendar which is joined to your sales_fact table and,
You have set up a relative dates class in your universe, as per this thread[/list]
