Get report fields means capture all objects, universe as well as report variables and display in a message box.
Or access report variables to update/modify.
What exactly you are looking for
one more doubt i have. Using ActiveDocument.DocumentVariable.count we can get the count of Variables available in a report.
In same note is there any method/function is available in SDK to find the formulas and constants used in a report.
Please suggest me how to retrieve the formulas and constants present in a report
Private Sub Document_BeforeRefresh(Cancel As Boolean)
Dim V_Cnt As Integer
Dim i As Long
V_Cnt = ThisDocument.DocumentVariables.Count
For i = 1 To V_Cnt
MsgBox ThisDocument.DocumentVariables.Item(i).Formula
Next i
End Sub
The .DocumentVariables collection includes ALL variables … data provider objects (.IsDataProviderObject property = True), named formulas (.Name property is filled in), as well as unnamed formulas and constants (.Name property is empty).
Heres a snippet from the process we have that loops through and documents our report structures – it probably does way more than you would need…but it should give you an idea for whats available.
Dim cellsubstructure, BlockSubStructure As ReportStructureItem
Dim piv As Pivot
Dim N As Integer
Dim docvar As DocumentVariable
Dim strStructureDesc As String
Dim strSQL As String
30 Select Case RepStructureItem.Type
'PROCESS TABLE
Case boTable
40 strType = "TABLE"
50 strStructureDesc = ""
60 Set BlockSubStructure = RepStructureItem
70 Set piv = BlockSubStructure.Pivot
80 For N = 1 To piv.BodyCount ' this represents the number of body objects in the block
90 Set docvar = piv.Body(N)
100 If docvar.Name > "" Then
110 If strStructureDesc = "" Then
120 strStructureDesc = docvar.Name & " | "
130 Else
140 strStructureDesc = strStructureDesc & docvar.Name & " | "
150 End If
160 Else
170 If strStructureDesc = "" Then
180 strStructureDesc = docvar.Formula & " | "
190 Else
200 strStructureDesc = strStructureDesc & docvar.Formula & " | "
210 End If
220 End If
230 Next N
240 strStructureDesc = Trim(strStructureDesc)
250 If Right(strStructureDesc, 1) = "|" Then
260 strStructureDesc = Left(strStructureDesc, Len(strStructureDesc) - 1)
270 End If
280 strStructureDesc = "Table [" & BlockSubStructure.Name & " ] " & " Created by Change Mgt. Import Process on " & CStr(Now()) & "." & Chr(13) & strStructureDesc
290 strStructureDesc = Replace(strStructureDesc, "'", "''")
'PROCESS CROSSTAB
300 Case boCrosstab
310 strType = "CROSSTAB"
320 strStructureDesc = ""
330 Set BlockSubStructure = RepStructureItem
340 Set piv = BlockSubStructure.Pivot
350 strStructureDesc = "Crosstab [ " & BlockSubStructure.Name & "] Body content --" & Chr(13)
360 For N = 1 To piv.BodyCount ' this represents the number of body objects in the block
370 Set docvar = piv.Body(N)
380 If docvar.Name > "" Then
390 If strStructureDesc = "" Then
400 strStructureDesc = docvar.Name & " | "
410 Else
420 strStructureDesc = strStructureDesc & docvar.Name & " | "
430 End If
440 Else
450 If strStructureDesc = "" Then
460 strStructureDesc = docvar.Formula & " | "
470 Else
480 strStructureDesc = strStructureDesc & docvar.Formula & " | "
490 End If
500 End If
510 strStructureDesc = Trim(strStructureDesc)
520 Next N
530 If Right(strStructureDesc, 1) = "|" Then
540 strStructureDesc = Left(strStructureDesc, Len(strStructureDesc) - 1)
550 End If
560 strStructureDesc = strStructureDesc & Chr(13) & "Crosstab [ " & BlockSubStructure.Name & "] Column content --" & Chr(13)
'PROCESS COLUMNS
570 For N = 1 To piv.ColumnsCount ' this represents the number of body objects in the block
580 Set docvar = piv.Columns(N)
590 If docvar.Name > "" Then
600 If strStructureDesc = "" Then
610 strStructureDesc = docvar.Name & " | "
620 Else
630 strStructureDesc = strStructureDesc & docvar.Name & " | "
640 End If
650 Else
660 If strStructureDesc = "" Then
670 strStructureDesc = docvar.Formula & " | "
680 Else
690 strStructureDesc = strStructureDesc & docvar.Formula & " | "
700 End If
710 End If
720 strStructureDesc = Trim(strStructureDesc)
730 Next N
740 If Right(strStructureDesc, 1) = "|" Then
750 strStructureDesc = Left(strStructureDesc, Len(strStructureDesc) - 1)
760 End If
'PROCESS ROWS
770 strStructureDesc = strStructureDesc & Chr(13) & "Crosstab [ " & BlockSubStructure.Name & "] Row content --" & Chr(13)
780 For N = 1 To piv.RowsCount ' this represents the number of body objects in the block
790 Set docvar = piv.Rows(N)
800 If docvar.Name > "" Then
810 If strStructureDesc = "" Then
820 strStructureDesc = docvar.Name & " | "
830 Else
840 strStructureDesc = strStructureDesc & docvar.Name & " | "
850 End If
860 Else
870 If strStructureDesc = "" Then
880 strStructureDesc = docvar.Formula & " | "
890 Else
900 strStructureDesc = strStructureDesc & docvar.Formula & " | "
910 End If
920 End If
930 strStructureDesc = Trim(strStructureDesc)
940 Next N
950 If Right(strStructureDesc, 1) = "|" Then
960 strStructureDesc = Left(strStructureDesc, Len(strStructureDesc) - 1)
970 End If
980 strStructureDesc = "Crosstab [" & BlockSubStructure.Name & " ] " & " Created by Change Mgt. Import Process on " & CStr(Now()) & "." & Chr(13) & strStructureDesc
990 strStructureDesc = Replace(strStructureDesc, "'", "''")
'PROCESS CHART/GRAPH
1000 Case boChart
1010 strType = "GRAPH/CHART"
1020 strStructureDesc = ""
1030 Set BlockSubStructure = RepStructureItem
1040 Set piv = BlockSubStructure.Pivot
1050 strStructureDesc = "Chart/Graph [ " & BlockSubStructure.Name & "] body content --" & Chr(13)
1060 For N = 1 To piv.BodyCount ' this represents the number of body objects in the block
1070 Set docvar = piv.Body(N)
1080 If docvar.Name > "" Then
1090 If strStructureDesc = "" Then
1100 strStructureDesc = docvar.Name & " | "
1110 Else
1120 strStructureDesc = strStructureDesc & docvar.Name & " | "
1130 End If
1140 Else
1150 If strStructureDesc = "" Then
1160 strStructureDesc = docvar.Name & " | "
1170 Else
1180 strStructureDesc = strStructureDesc & docvar.Formula & " | "
1190 End If
1200 End If
1210 strStructureDesc = Trim(strStructureDesc)
1220 Next N
1230 If Right(strStructureDesc, 1) = "|" Then
1240 strStructureDesc = Left(strStructureDesc, Len(strStructureDesc) - 1)
1250 End If
1260 strStructureDesc = "Chart/Graph [" & BlockSubStructure.Name & " ] " & " Created by Change Mgt. Import Process on " & CStr(Now()) & "." & Chr(13) & strStructureDesc
1270 strStructureDesc = Replace(strStructureDesc, "'", "''")
1280 End Select
