Report conversion issue
Hello every one !
I have few reports which were converted from XI R 2 to XI R 4.0 but they did not convert correctly. When you open the reports so each block has value as " multivalue". Can you please help why I am getting this error and whtas the solution to it. Thanks
junaid1987 (BOB member since 2013-08-08)
Try searching the WebI forum on the term “multivalue”
charlie :us: (BOB member since 2002-08-20)
There have been calculation changes between the two versions, quite often the brackets need to change position. You will have to re-work the formulas to get these working again.
OK this is the formula
=[Custom - Total Exceptions Approved 1M to 2.5M]+[Custom - Total Exceptions Unapproved 1M to 2.5M]+[Custom - Total Exceptions Approved 2.5M]+[Custom - Total Exceptions Unapproved 2.5M]
Can you tell now how can solve it. Thanks
Are those other Webi variables, or straight objects from the universe?
If they are other variables, how are they defined?
All Of these are variables defined at report level. And all of them have almost same kind of structure.
Well, maybe you can actually state what the syntax is for each of these.
Does simply wrapping a Sum() round the variable work.
=Sum([Custom - Total Exceptions Approved 1M to 2.5M]+[Custom - Total Exceptions Unapproved 1M to 2.5M]+[Custom - Total Exceptions Approved 2.5M]+[Custom - Total Exceptions Unapproved 2.5M])
The syntax is same but there is only difference in : approved and unapproved
=[Custom - Total Exceptions Unapproved 1M to 2.5M]
=[Custom - Total Exceptions approved 1M to 2.5M]
Again, please post the Webi syntax of all the variables.
Have you tried wrapping this in a Sum(), as I suggested earlier?
Yes I didnt work I even tried TO check avoid multiple aggregation that aslo didnt work :frowning:
Is there something we can do at universe level??
In the variables sintax there are any If ?
rgoulart :brazil: (BOB member since 2011-08-21)
That is likely to remain a mystery :roll_eyes:
These are dimension variable:
=If( ([Custom - Item]<>“Fin stmt quality”)And([Custom - Item]<>“Curr fin stmt borrower”)And([Custom - Item]<>“Current fin stmt guarantor”)And([Custom - Item]<>“Global cash flow analysis”)And([Custom - Item]<>“Moodys fin spread projection”)And([Custom - Item]<>“Current credit analysis”) ; “Non-Customer-level Exception” ; “Customer-level Exception”)
=If( (Left(Trim([Itemkey D]) ;1)=“1”) ; [Adhocdescription] ; (If( (Left(Trim([Itemkey D]) ;1)=“2”) ; [Adhocdescription] ; (If( (Left(Trim([Itemkey D]) ;1)=“3”) ; [Adhocdescription] ; (If( (Left(Trim([Itemkey D]) ;1)=“4”) ;[Adhocdescription] ; (If((Left(Trim([Itemkey D]) ;1)=“5”) ;[Adhocdescription] ; (If((Left(Trim([Itemkey D]) ;1)=“6”) ; [Adhocdescription] ; (If((Left(Trim([Itemkey D]) ;1)=“7”) ;[Adhocdescription] ; (If((Left(Trim([Itemkey D]) ;1)=“8”) ; [Adhocdescription] ; (If((Left(Trim([Itemkey D]) ;1)=“9”) ; [Adhocdescription] ; Replace(WordCap(Trim([Itemkey D])) ;"_" ;" "))))))))))))))))))
=[Custom - Region Name]+[Banknumber]+[Account Customer Name]+[Custom - Category]+[Custom - Item]+[Custom - Status]
=[Region 1]+[Banknumber]+[Category D]+[Custom - Status]+[Custom - Item]
=[Banknumber]+[Account Number]+[Note Number]+[Commitment Number]+[Current Commitment Amount]+[Note Current Balance]+[Custom - Total Relationship Debt]+[Custom - Item]+[Custom - Category]+[Custom - Status]+[Comments]+[Custom - Whether Above 1M]+[Custom - Whether Greater Than 2.5M]+[Custom - Exception Level]
=If( ([Custom - Total Relationship Debt] > 2500000) ; 1 ; 0)
= If( ([Custom - Total Relationship Debt] >= 1000000) ; 1 ; 0)
These are Measure variables:
=Sum(Count([Custom - Unique for Loan Account Level])ForEach([Xt Loanaccount Id] ; [Custom - Item] ; [Custom - Status])Where([Custom - Exception Level]=“Non-Customer-level Exception” And [Custom - Status] = “Approved” And [Custom - Whether Greater Than 2.5M] = 0))+Sum(Count([Custom - Unique for Customer Level])ForEach([Custom - Loan Account and Information])Where([Custom - Exception Level]=“Customer-level Exception” And [Custom - Status] = “Approved” And [Custom - Whether Greater Than 2.5M] = 0))
=Sum(Count([Custom - Unique for Loan Account Level])ForEach([Xt Loanaccount Id] ; [Custom - Item] ; [Custom - Status])Where([Custom - Exception Level]=“Non-Customer-level Exception” And [Custom - Status] = “Approved” And [Custom - Whether Greater Than 2.5M] = 1))+Sum(Count([Custom - Unique for Customer Level])ForEach([Custom - Loan Account and Information])Where([Custom - Exception Level]=“Customer-level Exception” And [Custom - Status] = “Approved” And [Custom - Whether Greater Than 2.5M] = 1))
=Sum(Count([Custom - Unique for Loan Account Level])ForEach([Xt Loanaccount Id] ; [Custom - Item] ; [Custom - Status])Where([Custom - Exception Level]=“Non-Customer-level Exception” And [Custom - Status] = “Not Approved” And [Custom - Whether Greater Than 2.5M] = 0))+Sum(Count([Custom - Unique for Customer Level])ForEach([Custom - Loan Account and Information])Where([Custom - Exception Level]=“Customer-level Exception” And [Custom - Status] = “Not Approved” And [Custom - Whether Greater Than 2.5M] = 0))
I hope it works
Ok we are getting there.
What are the names of the variables, how do they relate to:-
Custom - Item
Custom - Region + Banknumber + Category + Status + Item
And what do you mean how do they relate??
I did not create these reports.
Mak 1 wrote
If there was any conditional calculations (with an If), this could be generating a #Multivalue :wink: :wink:
What should be the solution to it???
Enclose your if with a Sum, like :
=Sum(If…)
I did that what happened is that Multivalue block has beeen replaced by a blank block. No data in the coloumn.
Anything we can do at the universe level???
Do you have more than one query in your document ?
