Replacing a particular date and blank with Blank
I am trying to find a logic to replace a particular date and blank space from blank.
For e.g. have 01/01/1800 as a date and want to change it by blank. But other dates should remain intact. Also if there is any blank date, it it should remain blank.
It should be simple enough. The big β€˜issue’ is the the result will not be a date anymore from the formula, but a string.
Example
if {somedate} = date(1900,01,01) then β€˜β€™
else cstr(somedate)
You may want to totext instead of cstr to get more control on the formatting.
kevlray :us: (BOB member since 2010-06-23)
Thank you so much for suggestion.
I managed to solve it by using date and totxt function. :slight_smile:
