Replace_Substr_Max_Size_Characters parameter in DSConfig.txt
I do get the warning message for most jobs run on BODS 4.2.
'The data returned by the <replace_subst> function could be truncated because return size is reduced from <15890> to <18200>. If data truncation occurs, adjust the Replace_Substr_Max_Size_Characters parameter in DSConfig.txt file.
We migrated the job from 3.2 version
Please advise.
its_ranjan (BOB member since 2011-02-16)
