replace special or control character from columns
I want to subsitute certain control character from description. I am trying to replace char(26) from description with ‘rr’. but this code is not working.
substr( Description,chr(26),‘rr’)
char(26) is ASCII code for square shape special character
any clue how to find and replace special char from columns
thanks in advance
GBS74 (BOB member since 2007-01-23)
Where do you see the Square Characters? It may not be really a square! If this is Microsoft SQL Server, it usually displays junk characters in that Square or for that case SAP also…
Let me know where you do see the boxes
@GBS74.
Search is your friend…
e.g. https://bobj-board.org/t/212873
Darth Services :uk: (BOB member since 2007-11-20)
