Repeating initial loads of an SAP RapidMart
I have to repeat the initial load of an SAP RapidMart (Sales).
However, even if the G_LOAD_TYPE global variable is set to first, the
many Workflows and Dataflows that have a property of Execute Only Once, will not be executed.
What is the least painful way of fixing this ( without reinstalling the RapidMart or having to go into individual Workflow\Dataflow and unticking the Execute Only Once Property and ticking it back after)?
Thanks in advance.
lenni :new_zealand: (BOB member since 2007-07-12)
Are you running it in “recover from last failed execution point” in the execution dialog options?
Execute-only-once means the dataflow/workflow starts once within the current job execution even if it is called from different places within that job.
https://www.sdn.sap.com/irj/scn/wiki?path=/display/BOBJ/Parallel%2bvs%2bsequential%2bExecution
My client had the “Recover from last failed execution” property ticked on. Thanks Werner.
Result, yeah! 8)
