Removing previouse values of prompt
Please help me how can I remove previous selected prompt value in my deski report. we are using Deski 11.5.
This report is using Free hand sql and has @variable function used for prompt. Below is the code.
@variable(‘EnterNum:’,‘A’,mono,free,Not_Persistent)
Even Not_Persistent is not working.
vrrm
vrrm (BOB member since 2008-08-04)
Instead of @variable() use @prompt() function.
And, purge the data provider and the previously selected prompt value will be gone.
Using @prompt also doenst work. I am getting the previous selected prompt value.
@Prompt(‘EnterNum:’,‘A’,mono,free,Not_Persistent,))
vrrm
Have you tried purging the data provider?
Yes. But purging is working for only first time. When user runs second time, prompt value is not purged.
