Removing parameters from Crystal XI Report
Long time BO Report developer, starting to work with some Crystal XI reports.
The reports I am editing were done by another employee and I am now having to make some modifications to the report.
The report is using a SQL View and Table as the datasource (Not a universe) and there is one sub-report.
The report has three parameters defined and I now need to remove two of those.
If I click on the parameter in the Field Explorer and then click the delete X I receive the message:
The field could not be deleted. To delete this field, you must remove all references to it in the report.
I don’t want to remove the field from the report, I just don’t want it to be a parameter any more.
Help on this would be most appreciated.
estaup (BOB member since 2002-10-15)
I have resolved this. I found I was able to do this through the Select Expert.
