system
December 31, 2007, 7:55am
1
Dear all,
I run into a situation where the DB designers made a database design where there is a loop.
I just do need all these tables you generate the correct set of data.
Important to know is that in we do not need any sum in the applicable reports.
If BO generates the SQL it looks like it’s the correct one.
So my question to you is:
Is it always needed to resolve this loop or are there situations where you can leave it as it is?
thx in advance
peter
PeetV (BOB member since 2006-04-20)
system
December 31, 2007, 8:49am
2
Please, look here or here or here…
We have a situation in our universe that is being identified as a loop but it’s really just a case where part of the foreign key resides in one table and part resides in the other. Some strange things are happening in the generated SQL and I was wondering if a context might help but I’m not sure it’s intended for something like this.
I have attached a piece of the universe diagram but to sum it up:
We determine what “service” a patient had by looking at a combination of the facility they visit…
I know, I know I searched I promise, but I am having problem with the terminology of trying to search based on my question.
Three tables A, B, and C. I need to create objects based on table C dependent on 4 values from table A and 1 from table B. Problem is, table A and B are joined and need to be, thus I have a loop. I am familiar with context and alias but not sure they will work for this situation. A context would define the correct path, but I really need both paths A-> C and B-> C defined…
etc.
In short, a loop might be necessary to get valid data, especially in highly normalized databases.
Andreas (BOB member since 2002-06-20)
system
December 31, 2007, 9:06am
3
Thx Andreas,
I’m gonna look into these articals.
peter
