Relationship BO document and webintelligence document
Hello,
At the moment I’m using only BO full client report (*.rep).
Many users use Business Objects infoview to consult the report. Is it possible to do a drill down of a Business Objects document in Infoview?
I managed to do a drill down of a webintelligence document in Infoview.
Kind regards
Moeri :belgium: (BOB member since 2005-05-03)
Full Client documents (*.rep files) cannot be drilled in Webi, but you can get tricky with Master/Detail sections possibly or by using the OpenDocument function (see here for details).
Only Webi documents (*.wid files) can be drilled when viewed in Webi.
