Regarding WEBI Report Layout
Hi Experts.
I have a requirement in developing a WEBI Report. The Report Layout is being attached.
The user will have a prompt inputs, lets say from Example Time frame A, Time Frame B and Profit Center (multiple single value).
The attachment shows the report layout where Value cut as no of profit centers selected which appears dynamically based on the user prompt inputs.
Please guide me to achieve this.
Thanks in advance
Santosh
WEBI_Report.xls (23.0 KB)
santoshsaraf (BOB member since 2009-10-15)
Good Day,
I think the best approach here is to create a cross-tab table for Time frame A and another 3 different table for time frame B and variance $ and variance %. now im assuming that its a fixed column table so you wouldnt be needing relative position. just connect them side by side.
Kindle tell me if im missing something.
John Vincent
jvmauricio :philippines: (BOB member since 2009-08-03)
I appreciate ur reply.
I can’t put the three different tables side by side, bcoz when the user changes the prompt input, lets say 5 profit centers, the tables will get overlap.
Is their any other solution where i can combine all the three tables dynamically based on the user prompt input.
Santosh
Could you position the tables underneath each other? A suggestion is to place each value selected from the user prompt in separate variables, and use these variables to filter out unwanted values in the specific block. In the first block, you can compare the first 2 values selected from the user prompt (and use the first 2 values in the block filter). I’m assuming then you’d compare the 3rd and 4th user response values, and then you can filter the block on those values inputted? Your sample only shows how the report looks for 2 cost centers.
bkaporch :us: (BOB member since 2008-12-02)
Thanks for the reply !!!
I have around 15 profit centers, and the user may choose any multiple combination values. Those values appear in the place of Value cut in the excel file which the user has chosen has multiple values.
What i was trying to do is, i created a cross tab, At the Top i Place Time frame A and Time frame B and then i created added a row below and tried to place the profit centers for both Time Frame A and Time Frame B.
Now the problem is, when i add the profit centers, its not able to show the chosen profit centers for Time Frame A as a group, instead it is showing Time Frame A, below 1 Profit center and then next column is Time Frame B and 1 profit center, where as my requirement is , i want All the Profit centers under one combination for Time Frame A and then Group of combination for Time Frame B.
Can this be done?
Help will be really appreciated !!!
Santosh
