regarding INFOVIEW
i am using ver 6.0 i am having a problem in loging into infoview home page.itz asking for user name and pswd…
i tried with the Business object pswd itz showing not able to reach repository USR 0045…(but i am able to login with the same user name in BO)…can any one help me
tnx in advance
ektha
Ektha (BOB member since 2004-07-26)
Hi Ektha
Make sure that you can reach to your repository db from your webi server. i.e. on the serever machine you installed webi 6.0
In other words make sure that you have installed proper middleware to connect to your repository db on your webi server.
BigV :australia: (BOB member since 2003-12-04)
thnx veera …I have chckd the connection itz responding… still i am not able to login.
can u please give me a link to set the webserver connection…for double check.
if you are using 6.0 release, you should try new 6.1b or 6.1.3 (i am currently downloading it)
maybe this problems have been corrected…
Did you copy the bomain.key to the locdata under node also?? That must be causing this issue…send me direct email and I can help you…
dcdas :us: (BOB member since 2002-06-17)
Moved from Webi 1.x/2.x to WebI 6.x forum, since that’s what the question was about.
