So I made a formula that involves 2 fields in my layout.
However I want to take these fields out my layout because they are not need for the layout and they break op my summing of the line (so instead of 1 amount I get 3 amounts which some to the correct total but I want to see 1 amount)
If I remove these fields from the layout the formula throws me a #multi error.
Is there a clever way around this?
Edit:
Perhaps it makes also more sense when I add the formula.
=If [Unit of measure]=“BX” And [Prod Hier Level 2 Text - Posted] InList (“PROGLIDE” ; “STARCLOSE SE” ;
“Engage Femoral Introducer” ; “FAST CATH INTRODUCER”) Then [Billed Q] * 10ElseIf ([Unit of measure]=“BX” And [Prod Hier Level 2 Text - Posted]=“SMALL ACCESSORIES 10PK”) Then [Billed Q]
ElseIf ([Unit of measure]=“BX”) Then [Billed Q] * 5
Else [Billed Q]
What I need is to take out the fields Units of measure and Prod Hier… But the formula then still needs to work (as it does now)
