Recurring Schedule > Instances
Is there a way, presumably using Query Builder, to tie an instance of a schedule back to the recurring schedule that created it?
For both, it seems the parent is the document the schedule ran and not the schedule itself. So, if there are multiple recurring schedules on a given document, tying the instances to the proper schedule is cumbersome.
BI 4.1
THANKS!!
jdean1012 :us: (BOB member since 2007-06-26)
Yes, the SI_NEW_JOB_ID property of an instance contains the ID of the recurring instance that spawned it.
Excellent. THANKS!
