Hi Folks
If we use a extractor to pull the data using BODS into an Oracle table or file , how can we use the logic for record mode, do we need to write our own logic to handle before and after image ?
Also if we see duplicates is there a way to handle this if we write to file. The duplicates are at key level, not the entire record is duplicated. Are we expected to handle duplicates while loading to the target or is there any setting in DS to handle duplicates.
Poonam
phemrajani (BOB member since 2012-06-02)
