Hi Guys,
Please can you suggest some quick way to read the SAP BW Write Optimized DSO data using Data Services ? . Can I can read directly from table which is used by this Write Optimized DSO or I have to Use the Open Hub to read the Data from Write optimized DSO using Data Services. I think so if I will use the Open Hup then I can get delta records because Write Optimized DSO in SAP BW does not contain Delta records.
Your quick great help would be highly appreciated.
Mubi
qazi (BOB member since 2012-05-09)
