I’ve been having trouble getting these to work in DI.
I’m on
XP SP3
SQL Server 2008
DI 12.2.3.0
Upon importing the table, DI classifies them as long which seems fair enough, but when I create a simple DF to try to extract data from the table
[Souce]->[Query]->[FlatFile]
It errors out near-immediately with an “Invalid descriptor index” error (twice, for some reason.) I never even get the “rows-per-commit reduced to 1 because of LONG” warning.
Viewing the data in the table still works (to the extent that anything classified as long only ever shows here anyways.)
I’ve been trying to assist a co-worker with this and nothing I try seems to work, though they have occasionally been getting a different error than I have: “The text, ntext, or image pointer value conflicts with the column name specified”
If anyone has any tips or guidance for working with varchar(MAX) (and nvarchar(max) varbinary(max) to boot, no doubt) we would definitely appreciate it.
We are migrating all the long-form text and binary columns in our database schema to nvarchar(max) and varbinary(max) because the text and image types are being deprecated.
To quote the SQL 2012 (was also present on SQL 2008) MSDN page on the ‘text’ type:
[quote:b42d269e74=“http://msdn.microsoft.com/en-us/library/ms187993.aspx”]ntext , text, and image data types will be removed in a future version of Microsoft SQL Server. Avoid using these data types in new development work, and plan to modify applications that currently use them. Use nvarchar(max), varchar(max), and varbinary(max) instead.
[/quote]
In this particular scenario, we aren’t using it in data warehousing; we are using it to export data from our system into a 3rd-party system. As soon as the table loader hits a table with a nvarchar(max) fields, it errors out with the invalid descriptor index error. Interestingly (or maybe not,) the error always shows up twice.
Yes, I will post my scenarios. I tested this elaborately. I am having PROD stuffs going on driving me crazy.
Just for your info, use the ODBC provided by Microsoft and not the one from SQL Server (SQL Sever Native Client) and the job shoudl work fine according to my testing…
Case 1: SQL Server Table involving a NVARCHAR(MAX) column and DS Datastore uses a Direct Connect (I mean no ODBCs)
Case 2: SQL Server Table involving a NVARCHAR(MAX) column and DS Datastore uses a SQL Server Driver provided by Microsoft Windows that is pre-installed when Windows gets installed
Case 3: SQL Server Table involving a NVARCHAR(MAX) column and DS Datastore uses a SQL Server Native Client Driver that comes with SQL Server 2008 Client Package
How DS Imports the Column?
Case 1: LONG - Direct Connection using Server Information and DB Information
Case 2: LONG - SQL Server Driver from Microsoft Windows
Case 3: VARCHAR(0) - SQL Server Native Client
Results:
Case 1: Invalid Descriptor Index
Case 2: Load completes successfully
Case 3: Invalid Descriptor Index
I am having the same issue. I followed the procedure as suggested by Ganesh and now the Invalid descriptor issue is resolved. I am able to fetch data from table but when I try to load the same table it throws error
“<The text, ntext, or image pointer value conflicts with the column name specified.>”
Am I doing something wrong. I have used an ODBC DS, the ODBC DSN is of SQL Server as provided by Microsoft.
:help…
I ran across this issue today when doing a proof of concept for a client. Ganesh, your solution worked for me just fine. Kudos for posting the solution.
Now, why on earth does the ODBC connection work when the native client connection doesn’t? Is this a bug in how DS is working with the driver?
Changing the ODBC driver caused us to lose windows authentication. We found a different workaround: create a separate dataflow which reads the varchar(max) data and inserts into template table. The insert pushes down to the database, so data is never read into memory. The data is implicitly converted from varchar(max) to text; which DS can handle in subsequent dataflows without trouble. text datatype is not optimal, but this gets us through the day.
I wasn’t sure about the ODBC configuration either, but I think I figured it out too.
For future people who may be usure:
Set up a system ODBC data source on both the development server and the job server using driver named just “SQL Server” (our version was 6.01.7601.17514, file SQLSRV32.DLL, 11/20/2010). (We also had several variations of “SQL Native Client”, file names like SQLNCLI.DLL and variations, which I did not try.)
Configured the datastore to be database type “ODBC” instead of “Microsoft SQL Server”, and chose the DSN I configured in step 1.
