READ_TEXT function
I am having issues executing job with READ_TEXT function. It throws an error that it is not RFC enabled.
Do anyone has steps how to make it RFC enabled. Or create another function similar to this but RFC enabled.
DataGenius (BOB member since 2006-06-13)
I dont have the TDP license but I believe that means it needs to be used in a real-time job.
jlynn73 :us: (BOB member since 2009-10-27)
Hi ,
This function is used for fetching the long text information from SAP. For this functional module (read_text) authorization assign to the user. So then you are able to use the function module in your query to get the long text information.
Thanks & Regards,
Ramana
Ramana :india: (BOB member since 2009-04-30)
