Read-only BODI Jobs ....
Few Questions Regarding Read-only BODI jobs …
  1. I want to make a BODI job as Read-only in prod …
  2. I want to make a project read-only (Secure Project) …
How can I make that one ?
We can make a full repository(DB) as read-only from DB perspective using grant permission … But
I want to do it in project or job level…
Can anybody please help me in this regard ?
HeadsUp (BOB member since 2011-01-14)
You should use a different model. My prod repo is secure because nobody knows the login for this repo. And nobody needs to as no development environment (=DS Designer) is allowed to connect to it. If new jobs/projects need to be moved into prod they are exported into an ATL file and imported automatically via the al_engine after thoroughly testing them.
Thanks for the reply Werner …
Is there any way to import jobs / project silently, without using DS Designer ? But we can export the Jobs / Project from the command prompt… Please suggest…
