Read cell contents to trigger alerter
Hi all,
I am using BO XI 3.1 WebIntelligence Rich Client to develop reports and have a question relating to alerters and the threshold that they are triggered on.
Normally when defining the threshold for an alerter, you can add a prompt and use the UserResponse function to determine the user defined value. E.g. if you want to highlight sales above a particular, you would include a prompt for sales threshold and use the UserResponse function in a variable, which in turn could be used in an alerter to highlight rows in a table that were above the prompt value.
However, every time you want to change the alert threshold, you have to refresh the report. I would like to have a some type of input (e.g. a free standing cell) where the user could type a value and change the trigger for the alerter. That way the user could change the alerter threshold without refreshing the report again - if the only value changing is the level of the threshold, then the refresh is a bit of a waste of time, particularly if the report takes a long time to refresh. Is it possible to do this in BO XI WebIntelligence reports?
tdeasy2000 (BOB member since 2007-02-09)
This is a new feature in SP2. I haven’t played around with it at all, but I have seen it in the documentation.
