Re-install process without BIAR
My BOXI R3.0 system is down due to installing CR 2008 SP1 on the same server. See post below for details of problem.
I need to reinstall BOXI R3.0 on the same server, but I do not have a BIAR file. If I have a copy of the Repository DB and the File Store, can I reinstall and point the new installation to the saved repository DB and file store? I have performed system migration on CE10 by just using the repository DB and file store, but I want to make sure before I try.
I have been searching these boards for the past 2 hours looking for an answer without much luck. Please let me know of a post or if you can give me the steps for saving my reports.
Thanks in advance.
Josh
BO_Loader :us: (BOB member since 2008-04-12)
Found one post here which may not be related to your version, but the procedure more or less the same
Is it a BO XI3.x repository database which stopped working on existing server and you want it to be pointed from another XI 3.x installation
No, the BOXI R3.0 installation had files overwritten by Crystal 2008 SP1. I couldn’t open the CCM due to missing DLL’s. Actually all the client tools wouldn’t open because of missing DLL’s. And CMS would fail to start.
I called in a support issue to SAP and I have the system back up and running. Had to re-install everything. Still having some small issues, but its back up and running.
