Hello there,
I am using Tomcat 6.0.35 ( 64 bit) to custom deploy my BO applications. I am not using the out of the box Tomcat that came with BOXI 31 install. We are using Windows 2008 R2.
One of the thing, I wanted to identofy is that , I do not have catalina.bat in /bin folder of Tomcat install. In that case, where do you define the Min and Max. Java heap parameters?
Sam
samshaw (BOB member since 2004-12-21)
