RAS SDK and column aliases
We have a requirement that users can select what columns appear on a report. This is like an ad-hoc report, but we are going to use Crystal for performance reasons. The FROM clause will not change. The user has the option to select which columns make up the SELECT clause. Reading about the RAS SDK that seems to be the weapon of choice. What I’ve not found is when specifying the columns for the SELECT clause can the SDK also handle passing column aliases. Is this possible? If so anything we should be mindful of?
Thanks for your time on this.
-Jim
Jim Barta (BOB member since 2009-04-01)
