Hi Friends
One of the purchasing rapid mart got failed after few minutes of processing, when i check the log I found the following error
- Violation of PRIMARY KEY constraint
2)Cannot insert duplicate key in object
Please find below the Log error
<<PTH-SAPSQL03.xxx.local>
Log: error_05_17_2012_20_20_03_901__83e6c6a4_9ac7_4c04_af8e_b32a1d86f0de.txt Job Server: PTH-SAPBO01:3500
Job name: Purchasing_Rapidmart_SAP
(12.2) 05-17-12 22:19:59 (W) (2376:10764) FIL-080102: |Data flow DF_FiscalPeriodNotYrSpecific_SAP|Reader R3_FiscPer_NOT_YrSpecific End of file was found without reading a complete row for file <//PTH-SAPERP01/sapXXX/trans/fiscalperiods.dat>. The expected number of columns was <8> while the number of columns actually read was <6>. Please check the input file for errors or verify the schema specification for the file format. The number of rows processed was <64016>. (12.2) 05-17-12 22:20:41 (E) (1184:4500) DBS-070404: |Data flow DF_FiscalPeriodDefault_SAP|Reader Query
SQL submitted to ODBC data source <PTH-SAPSQL03.XXX.local> resulted in error <[Microsoft][ODBC SQL Server Driver][SQL Server]Violation of PRIMARY KEY constraint
XPK_FISC_PERIOD’. Cannot insert duplicate key in object ‘dbo.FISC_PERIOD’.>.
The SQL submitted is <INSERT INTO “dbo”.“FISC_PERIOD” ( “FISC_YEAR” , “FISC_PERIOD” , “FISC_YR_VARIANT_ID” , “FISC_MONTH” , “START_DATE” , “END_DATE” , “FISC_QUARTER” , “FISC_HALF” , “CALENDAR_YEAR” , “CALENDAR_MONTH_NUMERIC” , “CALENDAR_MONTH_LONG” , “CALENDAR_MONTH_SHORT” , “CALENDAR_QUARTER” , “CALENDAR_HALF” , “SPECL_PERIOD_FLAG” , “FISC_YR_VARIANT_NAME” , “LOAD_DATE” , “LOAD_TIME” ) SELECT DISTINCT “FISC_PERIOD_STAGE”.“FISC_YEAR” , “FISC_PERIOD_STAGE”.“FISC_PERIOD” , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘1900-01-01 00:00:00.000’, 121) , CONVERT(DATETIME2, ‘9999-12-31 00:00:00.000’, 121) , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘2012-05-17 20:20:17.000’, 121) , ‘20:20:17’ FROM “dbo”.“FISC_PERIOD_STAGE” “FISC_PERIOD_STAGE” >.
(12.2) 05-17-12 22:20:41 (E) (1184:4500) DBS-054003: |Data flow DF_FiscalPeriodDefault_SAP|Reader Query SELECT query <INSERT INTO “dbo”.“FISC_PERIOD” ( “FISC_YEAR” , “FISC_PERIOD” , “FISC_YR_VARIANT_ID” , “FISC_MONTH” , “START_DATE” , “END_DATE” , “FISC_QUARTER” , “FISC_HALF” , “CALENDAR_YEAR” , “CALENDAR_MONTH_NUMERIC” , “CALENDAR_MONTH_LONG” , “CALENDAR_MONTH_SHORT” , “CALENDAR_QUARTER” , “CALENDAR_HALF” , “SPECL_PERIOD_FLAG” , “FISC_YR_VARIANT_NAME” , “LOAD_DATE” , “LOAD_TIME” ) SELECT DISTINCT “FISC_PERIOD_STAGE”.“FISC_YEAR” , “FISC_PERIOD_STAGE”.“FISC_PERIOD” , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘1900-01-01 00:00:00.000’, 121) , CONVERT(DATETIME2, ‘9999-12-31 00:00:00.000’, 121) , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘2012-05-17 20:20:17.000’, 121) , ‘20:20:17’ FROM “dbo”.“FISC_PERIOD_STAGE” “FISC_PERIOD_STAGE” > failed. The database error message is <SQL submitted to ODBC data source <PTH-SAPSQL007.XXX.local> resulted in error <[Microsoft][ODBC SQL Server Driver][SQL Server]Violation of PRIMARY KEY constraint ‘XPK_FISC_PERIOD’. Cannot insert duplicate key in object ‘dbo.FISC_PERIOD’.>. The SQL submitted is <INSERT INTO “dbo”.“FISC_PERIOD” ( “FISC_YEAR” , “FISC_PERIOD” , “FISC_YR_VARIANT_ID” , “FISC_MONTH” , “START_DATE” , “END_DATE” , “FISC_QUARTER” , “FISC_HALF” , “CALENDAR_YEAR” , “CALENDAR_MONTH_NUMERIC” , “CALENDAR_MONTH_LONG” , “CALENDAR_MONTH_SHORT” , “CALENDAR_QUARTER” , “CALENDAR_HALF” , “SPECL_PERIOD_FLAG” , “FISC_YR_VARIANT_NAME” , “LOAD_DATE” , “LOAD_TIME” ) SELECT
‘?’ , CONVERT(DATETIME2, ‘2012-05-17 20:20:17.000’, 121) , ‘20:20:17’ FROM “dbo”.“FISC_PERIOD_STAGE” “FISC_PERIOD_STAGE” >.>.
(12.2) 05-17-12 22:20:41 (E) (11324:6880) DBS-054003: |Data flow DF_FiscalPeriodDefault_SAP|Reader Query SELECT query <INSERT INTO “dbo”.“FISC_PERIOD” ( “FISC_YEAR” , “FISC_PERIOD” , “FISC_YR_VARIANT_ID” , “FISC_MONTH” , “START_DATE” , “END_DATE” , “FISC_QUARTER” , “FISC_HALF” , “CALENDAR_YEAR” , “CALENDAR_MONTH_NUMERIC” , “CALENDAR_MONTH_LONG” , “CALENDAR_MONTH_SHORT” , “CALENDAR_QUARTER” , “CALENDAR_HALF” , “SPECL_PERIOD_FLAG” , “FISC_YR_VARIANT_NAME” , “LOAD_DATE” , “LOAD_TIME” ) SELECT DISTINCT “FISC_PERIOD_STAGE”.“FISC_YEAR” , “FISC_PERIOD_STAGE”.“FISC_PERIOD” , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘1900-01-01 00:00:00.000’, 121) , CONVERT(DATETIME2, ‘9999-12-31 00:00:00.000’, 121) , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘2012-05-17 20:20:17.000’, 121) , ‘20:20:17’ FROM “dbo”.“FISC_PERIOD_STAGE” “FISC_PERIOD_STAGE” > failed. The database error message is <SQL submitted to ODBC data source <PTH-SAPSQL007.XXX.local> resulted in error <[Microsoft][ODBC SQL Server Driver][SQL Server]Violation of PRIMARY KEY constraint ‘XPK_FISC_PERIOD’. Cannot insert duplicate key in object ‘dbo.FISC_PERIOD’.>. The SQL submitted is <INSERT INTO “dbo”.“FISC_PERIOD” ( “FISC_YEAR” , “FISC_PERIOD” , “FISC_YR_VARIANT_ID” , “FISC_MONTH” , “START_DATE” , “END_DATE” , “FISC_QUARTER” , “FISC_HALF” , “CALENDAR_YEAR” , “CALENDAR_MONTH_NUMERIC” , “CALENDAR_MONTH_LONG” , “CALENDAR_MONTH_SHORT” , “CALENDAR_QUARTER” , “CALENDAR_HALF” , “SPECL_PERIOD_FLAG” , “FISC_YR_VARIANT_NAME” , “LOAD_DATE” , “LOAD_TIME” ) SELECT
00:00:00.000’, 121) , CONVERT(DATETIME2, ‘9999-12-31 00:00:00.000’, 121) , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , -1 , ‘?’ , ‘?’ , ‘?’ , CONVERT(DATETIME2, ‘2012-05-17 20:20:17.000’, 121) , ‘20:20:17’ FROM “dbo”.“FISC_PERIOD_STAGE” “FISC_PERIOD_STAGE” >.>.
Please help in resolving this error.
Thanks in advance
fasi
Md_Fasi (BOB member since 2011-11-19)
